24 require terms and conditions at every login
Looking to force users to approve terms and conditions at every login. I have it working for first broker login, but need to have it at every login.
I don’t know that you can do this with the built-in T&C required action. You could probably extend it and always re-add it to the user in the evaluateTriggers method, but this would require installing a custom extension.
You can implement your custom event listener, and listen on events like login. On that event handler you can simply add on the logged in user the T&C required action. Should work.
