I have created a client in keycloak that will be used by our staff account server. We then try connecting to our keycloak server from a NodeJS app, using ‘keycloak-admin’, but in doing so we get a 400 error.
In Keycloak, for our client, the settings of note:
- Settings:
- Client Protocol: openid-connect
- Access Type: bearer-only
- Credentials:
- Client Authenticator: Client Id and Secret
Then in the NodeJS app which uses ‘keycloak-admin’:
async accessContext () {
const kcAdminClient = new KcAdminClient({
baseUrl: this.baseUrl,
realmName: this.realm
// Not the real client secret
await kcAdminClient.auth({
grantType: 'client_credentials',
clientId: 'staff-account-server',
clientSecret: '0f65bbed-0000-0000-ad1c-19a4085e10c0'
return kcAdminClient;
In doing this I get the following error:
Error: {"message":"Request failed with status code 400","name":"Error","stack":"Error: Request failed with status code 400\n at createError (/Users/ajmas/Development/my-project/node_modules/keycloak-admin/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/Users/ajmas/Development/my-project/node_modules/keycloak-admin/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/Users/ajmas/Development/my-project/node_modules/keycloak-admin/node_modules/axios/lib/adapters/http.js:260:11)\n at IncomingMessage.emit (events.js:327:22)\n at endReadableNT (_stream_readable.js:1327:12)\n at processTicksAndRejections (internal/process/task_queues.js:80:21)","config":{"url":"https://keycloak-test.somedomain.com/auth/realms/master/protocol/openid-connect/token","method":"post","data":"client_id=staff-server&grant_type=client_credentials","headers":{"Accept":"application/json, text/plain, */*","Content-Type":"application/x-www-form-urlencoded","User-Agent":"axios/0.21.1","Content-Length":52},"auth":{"username":"staff-account-server","password":"0f65bbed-0000-0000-ad1c-19a4085e10c0"},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1}}
BTW While I can work around with a grant type of password, for basic admin connectivity, the passport adapter we are planning to use, @exlinc/keycloak-passport, would have issues, since this needs client id and client secret.
I am suspecting there are some configurations I probably missed on the Keycloak side, but I am not sure what they are? Can anyone suggest what I should be looking at?
