404 - Not Found
Hi everybody; i have installed keycloak (standalone) . After i have installed a certificate for the server , i become the 404 - Not Found error message . The certificate has no problem und in the browser i can see it with the right informations and the connection under https with the server is secure . in the server log is the error message like below :
020-08-14 10:31:33,640 ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation (“add”) failed - address: ([
(“subsystem” => “ejb3”),
(“service” => “remote”)
]) - failure description: {
“WFLYCTL0412: Required services that are not installed:” => [“jboss.remoting.remotingConnectorInfoService.http-remoting-connector”],
“WFLYCTL0180: Services with missing/unavailable dependencies” => [“org.wildfly.clustering.cache.registry-entry.ejb.client-mappings is missing [jboss.remoting.remotingConnectorInfoService.http-remoting-connector]”]
I would realy thank you , if you could give me some tips , thanks :))
Mazyar
