Hi everyone, I am a bit stuck on an ssl related problem, I have configured an apache reverse proxy and then put keycloak behind it and installed the “app-authz-vanilla” application from the github quickstart to test my configurations, now everything works as intended I have generated the certificates for the web server virtual host and imported them into the wildfly server that the application is running, the wildfly server that has the application running is on a different host than where the keycloak server and the web server/reverse proxy is, each one has its own server, when I put the ssl-required argument to all in the keycloak.json of the application I always get a permission denied error and on the server.log I see that it says that “the adapter requires ssl” and then there is an http url of the endpoint, I don’t really know how to go about this as, is there something I need to do in order to secure my application like set up a java keystore? I’m sorry if this question might sound stupid but I have been stuck on it for a few days.
Thank you very much in advance!
