Hi, I would like to enable production mode on my Keycloak Chart ( bitnami, latest) but can’t find a way how to do it.
The Docs say I should
set KEYCLOAK_PRODUCTION to true and configure TLS
I have configured TLS already, but I don’t know where I should specify the ‘KEYCLOAK_PRODUCTION’ variable.
Anyone here who can help me? Thanks in advance
Pascal
Hey @PascalF I have same problem, I used bitnami helm chart and I deployed kc 18.0.2, but I can set “production mode” or “environment prod”
Did you fix it yet ?
and it should work theoretically - BUT in my case it only worked if your helm chart version is v9.3.3 or lower.
Once you try to use a higher version it will throw a JDBC Connection error (and I haven’t found out how to fix it yet)
