Hello everyone, how can I add oneadditional field in client setting page so that i can store some data for every client or is there some other way to store some data and i also want to get this data in client REST API?
Thank you
Thank you
Use client attributes and customize client-detail.html
template. SAML config options use client attributes, so just mimic them.
But nothing stopping you to use Admin REST API (even without template modification). Client model has attributes
, where you can save whatever you want (just use unique key, which will not collide with another Keycloak keys), e.g.:
"attributes": {
"my-unique-key": "data which I want to save"
If you don’t understand, just create some SAML client, export it and check exported json client model to see how attributes are used.
@jangaraj Thanks, one last thing i want to ask, Can i save this client attributes value via Keycloak Admin Console or any override method that i can use in standalone module?
