Hi. I’m struggling to make keycloak and ADLS (active directory lightweight directory services) to work “properly”.
I’m able to create users, but for some reason they are created disabled on the ADLDS backend.
Anyone had a similar problem?
Best regards
Jose
Jose could you show how did the setup, i am struggling with the basic setup here.
Hi. In this process I discovered that for almost any write operation on the ADLDS backend you need to user and ssl connection with the ADLDS servers. Without this, you can only read data from the ADLDS. To implement the SSL you will need to import the server certificate into keycloacks keystore. Without this you must be able to at least connect and import users to keycloak (if you want to import).
Best regards
Jose
