Admin console is not accessible without appended relative path value
Recently we migrated from v15 to v25. We needed to keep legacy /auth in the path, hence relative path parameter was used. Now every time we access the KC admin console we need to append /auth to the host (i.e. https://my.keycloak.com/auth instead of just https://my.keycloak.com). Whenever we make a request without /auth, the response is Resource not found. What is wrong with my configuration?
keycloak_relative_path = "/auth"
service_environment = [
        "name": "KC_DB_URL_HOST",
        "value": var.database.address
        "name" : "KC_DB_URL_DATABASE",
        "value" : var.database.db_name
        "name" : "KC_DB_SCHEMA",
        "value" : "public"
        "name" : "KC_DB",
        "value" : "postgres"
        "name" : "KEYCLOAK_USER",
        "value" : "admin"
        "name": "KC_HTTP_RELATIVE_PATH",
        "value": local.keycloak_relative_path
        "name": "KC_LOG_LEVEL",
        "value": "INFO"
        "name": "KC_LOG_CONSOLE_OUTPUT",
        "value": "json"
        "name": "KC_LOG",
        "value": "console"
        "name" : "KC_HOSTNAME",
        "value" : format("%s%s", var.keycloak_hostname, local.keycloak_relative_path)
        "name" : "KC_PROXY_HEADERS",
        "value" : "forwarded"
        "name" : "KC_HTTP_ENABLED",
        "value" : "true"
        "name" : "KC_HEALTH_ENABLED",
        "value" : "true"
You need to set the admin hostname as well if you don’t want it to share the same endpoint as hostname: KC_HOSTNAME_ADMIN
More details here: Configuring the hostname (v2) - Keycloak
If you set the KC_HTTP_RELATIVE_PATH, you always will have to add this path to your URL if you just enter the root path. Keycloak won’t redirect to the relative path. Thus, showing the 404/Resource not found.
