keycloak 18.0.0 running in podman container
I enabled email verification on the admin account, but sending email doesn’t work and I can’t log in via the admin account anymore.
Take a look at the ENTITY database table and verify your user is there? Also you could check the CREDENTIAL table and try to gleam what’s up with your password. Manually adding the reset_password action to your admin user could trigger a resetup of the password flow; seems like something might have gone wrong with that.
Are their any logs or user events to narrow down what the error event could be?
Hi ben.overcash
it shows error of Failed to send email: org.keycloak.email.EmailException: Please provide a valid address
Is it possible to disable email verification via cli?
2023-02-17 22:32:21,363 ERROR [org.keycloak.services] (executor-thread-307) KC-SERVICES0029: Failed to send email: org.keycloak.email.EmailException: Please provide a valid address
at org.keycloak.email.DefaultEmailSenderProvider.toInternetAddress(DefaultEmailSenderProvider.java:167)
at org.keycloak.email.DefaultEmailSenderProvider.send(DefaultEmailSenderProvider.java:126)
at org.keycloak.email.freemarker.FreeMarkerEmailTemplateProvider.send(FreeMarkerEmailTemplateProvider.java:264)
at org.keycloak.email.freemarker.FreeMarkerEmailTemplateProvider.send(FreeMarkerEmailTemplateProvider.java:259)
at org.keycloak.email.freemarker.FreeMarkerEmailTemplateProvider.send(FreeMarkerEmailTemplateProvider.java:250)
at org.keycloak.email.freemarker.FreeMarkerEmailTemplateProvider.send(FreeMarkerEmailTemplateProvider.java:207)
at org.keycloak.email.freemarker.FreeMarkerEmailTemplateProvider.sendVerifyEmail(FreeMarkerEmailTemplateProvider.java:181)
at org.keycloak.authentication.requiredactions.VerifyEmail.sendVerifyEmail(VerifyEmail.java:160)
at org.keycloak.authentication.requiredactions.VerifyEmail.requiredActionChallenge(VerifyEmail.java:81)
at org.keycloak.services.managers.AuthenticationManager.executeAction(AuthenticationManager.java:1327)
at org.keycloak.services.managers.AuthenticationManager.lambda$executionActions$15(AuthenticationManager.java:1275)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.stream.SortedOps$RefSortingSink.end(SortedOps.java:400)
at java.base/java.util.stream.Sink$ChainedReference.end(Sink.java:258)
at java.base/java.util.stream.DistinctOps$1$2.end(DistinctOps.java:168)
at java.base/java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:503)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:488)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.FindOps$FindOp.evaluateSequential(FindOps.java:150)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.findFirst(ReferencePipeline.java:543)
at org.keycloak.services.managers.AuthenticationManager.executionActions(AuthenticationManager.java:1276)
at org.keycloak.services.managers.AuthenticationManager.actionRequired(AuthenticationManager.java:1149)
at org.keycloak.services.managers.AuthenticationManager.nextActionAfterAuthentication(AuthenticationManager.java:996)
at org.keycloak.services.resources.LoginActionsService.processRequireAction(LoginActionsService.java:1003)
at org.keycloak.services.resources.LoginActionsService.requiredActionGET(LoginActionsService.java:985)
at jdk.internal.reflect.GeneratedMethodAccessor568.invoke(Unknown Source)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:71)
2023-02-17 22:32:21,363 ERROR [org.keycloak.authentication.requiredactions.VerifyEmail] (executor-thread-307) Failed to send verification email: org.keycloak.email.EmailException: org.keycloak.email.EmailException: Please provide a valid address
at org.keycloak.email.DefaultEmailSenderProvider.send(DefaultEmailSenderProvider.java:153)
Caused by: org.keycloak.email.EmailException: Please provide a valid address
… 75 more
2023-02-17 22:32:21,369 WARN [org.keycloak.events] (executor-thread-307) type=SEND_VERIFY_EMAIL_ERROR, realmId=cc899e01-abf7-4fe0-9658-2dc8cd7ab505, clientId=security-admin-console, userId=805ca960-2d1b-49bf-a046-bd1714bbfbb6, ipAddress=10.0.2.100, error=email_send_failed, auth_method=openid-connect, response_type=code, redirect_uri=http://10.83.107.178:8080/admin/master/console/, remember_me=false, code_id=1b935362-9fa4-4598-ba11-21a80b5dfdd5, email=lucas.franco@codex.com.br, response_mode=fragment, username=admin, authSessionParentId=1b935362-9fa4-4598-ba11-21a80b5dfdd5, authSessionTabId=z9KibwhOKNo
I managed to resolve.
I edited the ENTITY table, put it as verified email for the admin.
Thank you for your help ben.overcash
