Am not able to login in
Hi!
I am facing a problem where , I am not able to login in to the admin console with correct credentials
It gets stuck in a loop
how do i fix this
Could you give us more information about how you deploy your keycloak instance ? (environment variables, deployment type, logs)
Here is the log I am getting when it get stuck in the loop
WARN [org.keycloak.events] (default task-8) type=CODE_TO_TOKEN_ERROR, realmId=master, clientId=security-admin-console, userId=null, ipAddress=127.0.0.1, error=invalid_client_credentials, grant_type=authorization_code
2023-01-11 06:56:40,039 WARN [org.keycloak.events] (default task-8) type=CODE_TO_TOKEN_ERROR, realmId=master, clientId=security-admin-console, userId=null, ipAddress=127.0.0.1, error=invalid_client_credentials, grant_type=authorization_code
Did you specify KEYCLOAK_ADMIN and KEYCLOAK_ADMIN_PASSWORD to override the credentials ? And which version are you using ?
thanks for the time
it’s working now
am using the 15.0.2 version
