I have recently updated to a new instance of Keycloak 17.0.1 and it has mostly been smooth sailing but recently I noticed a few of the tabs on the admin console do not load.
When I try to open the Identity Providers, Events, Import, or Export tab for any realm including a brand new test realm I get a JavaScript error Failed to load resource 404 as part of the $templateRequest:tpload function in Angular JS
Failed to load resource: the server responded with a status of 404 ()
https://auth.mydomain.com/resources/klz7t/admin/keycloak/partials/notfound.html
Error: [$templateRequest:tpload] http://errors.angularjs.org/1.8.0/$templateRequest/tpload?p0=%2Fresources%2Fklz7t%2Fadmin%2Fkeycloak%2Fpartials%2Fnotfound.html&p1=404&p2=
at angular.min.js:7:168
at angular.min.js:168:19
at angular.min.js:140:235
at m.$digest (angular.min.js:151:385)
at m.$apply (angular.min.js:155:259)
at k (angular.min.js:106:309)
at v (angular.min.js:111:422)
at XMLHttpRequest.y.onload (angular.min.js:112:335)
Everything else appears to be fine and I am able to log into my services using Keycloak. Is there an obvious reason this doesn’t work and why it seems that items under /resources does not load?
For reference Keycloak is installed in its own Proxmox CT with Postgres as the database. It is running behind Cloudflare and HAProxy on my pfSense firewall. I am connecting to keycloak on port 8443 using proxy mode reencrypt.
