I have configured a working webdav using apache but now I am extending the authentication to use Keycloak oidc.
Following the guide on this page (Create new page · dcm4che/dcm4chee-arc-light Wiki · GitHub) I have been able to get the token from the client.
When I try to use the token to login to the webdav gives back HTTP code 302.
What is wrong in my configuration? Is it in the Keycloak configuration or the apache?
The commands I use is:
curl -H "Authorization: Bearer $TOKEN" -X PROFIND https://192.168.1.2/webdav/ -H "Depth: 1" --insecure
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://192.168.1.1:8080/auth/realms/example/protocol/openid-connect/auth?response_type=code&scope=openid&client_id=exampleclient&state=uIbkOihCIwugi2xnNcxMCxTsFTA&redirect_uri=https://192.168.1.2/webdav?nonce=XXXXXXXXXXXXXX">here</a>.</p>
</body></html>
My apache configuration looks like this.
> OIDCProviderMetadataURL http://192.168.1.1:8080/auth/realms/example/.well-known/openid-configuration
OIDCClientID exampleclient OIDCClientSecret 66139c06-57ff-4cfa-acdf-d1dca7024106 OIDCRedirectURI https://192.168.1.2/webdav OIDCCryptoPassphrase jj324kl5jkl32BB! <Location /webdav> DAV On SSLRequireSSL Options None AuthType openid-connect Require valid-user </Location>
Using the follow redirect flag in curl like this:
curl -L -H "Authorization: Bearer $TOKEN" -X PROFIND https://192.168.1.2/webdav/ -H "Depth: 1" --insecure
Then I get this error message:
{“error”:“RESTEASY003650: No resource method found for PROFIND, return 405 with Allow header”}
