API Gateway and Keycloak Integration
Has anyone done any integration work with Keycloak and AWS API Gateway? If so, can you please share the details or repo location.
AWS API Gateway doesn’t have direct support for OIDC. You need to write custom authenticator (Lambda), where you have to handle that based on your need, e. g. bearer token verification from the header.
Some implementations:
Thank you for the links. Have you seen anywhere else use of Keycloak-Gatekeeper/Louketo Proxy/Oauth Proxy ??
How do I integrate if user is not coming from UI i.e login page. like in the case when API Gateway is being called from python script.
