Application Initiated Actions - Case Sensitivity?
Hello together,
we’re using Keycloak running in Docker (bitnami/keycloak to be exact) to authenticate users. Using the application initiated actions (AIA) we want to let users update their password, delete their account, etc. Additionally, we also use a custom UPDATE_PROFILE to require users to reauthenticate before changing their profile (see: Require Reauthentication for Update Profile). This works quite nicely, however we’ve encountered a weird edge case: The kc_action needs to be in an exact case for our AIA to work. For instance ‘kc_action=delete_account’ works, but ‘kc_action=DELETE_ACCOUNT’ throws the following exception:
java.lang.NullPointerException: Cannot invoke "org.keycloak.authentication.RequiredActionProvider.getMaxAuthAge()" because "requiredActionProvider" is null.
However, for update profile and password, the case is reversed. It works for ‘kc_action=UPDATE_PASSWORD’ and ‘kc_action=UPDATE_PROFILE’, but using the lower-case spelling ‘kc_action=update_password’ or ‘kc_action=update_profile’ throws the same exception:
Failed authentication: java.lang.NullPointerException: Cannot invoke "org.keycloak.authentication.RequiredActionProvider.getMaxAuthAge()" because "requiredActionProvider" is null.
Now to my question: Is this the correct behavior or is there some kind of setting that we did not set or set incorrectly?
That’s the result of different developers writing different code without having proper coding conventions and checks. Just like in any other regular project… :sweat_smile:
The proper value to use is always the value the getId() factory method returns.
Ah! So provider_id for delete_account is lower case (keycloak/services/src/main/java/org/keycloak/authentication/requiredactions/DeleteAccount.java at main · keycloak/keycloak · GitHub) but for the other required actions the Enum name is used, which is upper case (keycloak/server-spi/src/main/java/org/keycloak/models/UserModel.java at main · keycloak/keycloak · GitHub). Alright, then we have to be careful when building the AIA. Thank you very much for clearing that up!
