I’m trying to initialize my keycloak-js adapter in my code with tokens I get from an external resource.
I see when debugging it does work but some code in the adapter calls clearToken afterwards and resets my tokens.
My code does:
keycloakInstance.init({
enableLogging: true,
token: data.access_token,
refreshToken: data.refresh_token
I can see in debug that the function messageCallback defined under setupCheckLoginIframe does this check:
if (event.data != 'unchanged') {
kc.clearToken();
And that’s what resets the token I’ve set using the init function.
Is there something to do about it? is this intentional or a bug?
