Authentication via OIDC issue
I have Keycloak 21.0.0 with 2 realms. Realms are identical except name.
In each realm I have external IDP. Also the same.
Only difference is a call-back URL which has realm name.
On one realm everything works fine. On another realm I cannot authenticate and Keycloak shows exception type=IDENTITY_PROVIDER_LOGIN_ERROR
2023-03-14 22:01:32,103 ERROR [org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider] (executor-thread-166) Failed to make identity provider oauth callback: org.keycloak.broker.provider.IdentityBrokerException: Could not fetch attributes from userinfo endpoint.
        at org.keycloak.broker.oidc.OIDCIdentityProvider.getFederatedIdentity(OIDCIdentityProvider.java:424)
        at org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider$Endpoint.authResponse(AbstractOAuth2IdentityProvider.java:505)
        at jdk.internal.reflect.GeneratedMethodAccessor1047.invoke(Unknown Source)
        at java.base/java.lang.reflect.Method.invoke(Method.java:568)
        at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: org.keycloak.broker.provider.IdentityBrokerException: Invalid token
        at org.keycloak.broker.oidc.OIDCIdentityProvider.validateToken(OIDCIdentityProvider.java:623)
        at org.keycloak.broker.oidc.KeycloakOIDCIdentityProvider.processAccessTokenResponse(KeycloakOIDCIdentityProvider.java:70)
        at org.keycloak.broker.oidc.OIDCIdentityProvider.extractIdentity(OIDCIdentityProvider.java:539)
        at org.keycloak.broker.oidc.OIDCIdentityProvider.getFederatedIdentity(OIDCIdentityProvider.java:405)
        ... 48 more
Caused by: org.keycloak.jose.jws.JWSInputException: java.lang.IllegalArgumentException: Parsing error
        at org.keycloak.jose.jws.JWSInput.<init>(JWSInput.java:59)
        at org.keycloak.broker.oidc.OIDCIdentityProvider.validateToken(OIDCIdentityProvider.java:617)
        ... 51 more
Caused by: java.lang.IllegalArgumentException: Parsing error
        at org.keycloak.jose.jws.JWSInput.<init>(JWSInput.java:46)
        ... 52 more
Brief googling shows that this is something related to the SSL settings. But they are identical.
I can authenticate with Postman with both call-back URLs emulating both my realms.
Any advice where to look?
Hey,
Kind a weird indeed, I would verify IDP configuration on both realms.
Also, you could take a look at : Loading...
Maybe you have disable it on one realm and not in the other ?
No. Userinfo endpoint replies perfectly fine. And I can get userinfo via Postman.
As I can see from the logs this is somehow related to the token itself.
This is not related to the realm name: I can rename “working” realm to “non-working” and it works fine.
I configure the same IDP in the master realm (IDP allows this callback URL) and… it doesn’t work as well. Something related to IDP actually. But not clear what exactly.
