Hi need help on this error :
KeyError: ‘applyPolicies’
Log:
Starting development server at http://127.0.0.1:8000/
Quit the server with CTRL-BREAK.
Exception in thread Thread-1:
Traceback (most recent call last):
File “C:\Users\Admin\AppData\Local\Programs\Python\Python36\lib\threading.py”, line 916, in _bootstrap_inner
self.run()
File “C:\Users\Admin\AppData\Local\Programs\Python\Python36\lib\threading.py”, line 864, in run
self._target(*self._args, **self.kwargs)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\utils\autoreload.py”, line 54, in wrapper
fn(*args, **kwargs)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\management\commands\runserver.py”, line 137, in inner_run
handler = self.get_handler(*args, **options)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\contrib\staticfiles\management\commands\runserver.py”, line 27, in get_handler
handler = super().get_handler(*args, **options)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\management\commands\runserver.py”, line 64, in get_handler
return get_internal_wsgi_application()
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\servers\basehttp.py”, line 45, in get_internal_wsgi_application
return import_string(app_path)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\utils\module_loading.py”, line 17, in import_string
module = import_module(module_path)
File "C:\Users\Admin\AppData\Local\Programs\Python\Python36\lib\importlib_init.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 994, in _gcd_import
File “”, line 971, in _find_and_load
File “”, line 955, in _find_and_load_unlocked
File “”, line 665, in _load_unlocked
File “”, line 678, in exec_module
File “”, line 219, in call_with_frames_removed
File “D:\keycloak\DjangoBackEnd\autointelliBackEnd\autointelliBackEnd\wsgi.py”, line 16, in
application = get_wsgi_application()
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\wsgi.py”, line 13, in get_wsgi_application
return WSGIHandler()
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\handlers\wsgi.py”, line 135, in init
self.load_middleware()
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\django\core\handlers\base.py”, line 37, in load_middleware
mw_instance = middleware(handler)
File “D:\keycloak\DjangoBackEnd\autointelliBackEnd\autointelliBackEnd\middleware.py”, line 58, in init
self.keycloak.load_authorization_config(self.keycloak_authorization_config)
File “D:\keycloak\DjangoBackEnd\env\lib\site-packages\keycloak\keycloak_openid.py”, line 357, in load_authorization_config
self.authorization.load_config(authorization_json)
File "D:\keycloak\DjangoBackEnd\env\lib\site-packages\keycloak\authorization_init.py", line 80, in load_config
for policy_name in ast.literal_eval(pol[‘config’][‘applyPolicies’]):
OS: windows
System check identified no issues (0 silenced).
June 18, 2020 - 16:41:33
Django version 2.2, using settings ‘autointelliBackEnd.settings’
self.run()
fn(*args, **kwargs)
