I’m quite new to Keycloak and I can’t get Keycloak to work behind AWS ALB for the life of me. This is my Target Group which is “healthy”
My ALB is Internet Facing and has HTTPS listening which then fwds to my Target Group
I’m running Keycloak version 11.0.2 on Ubuntu Bionic 18.04 with a firewall that accepts 22/8080/8443/443 from everything.
My Security Groups in AWS for Application Load Balancer allows 8080/443/8443 from Public
and finally, this is my standalone.xml for the sections that need to be configured
http-listener name=“default” socket-binding=“http” proxy-address-forwarding=“true” redirect-socket=“https” enable-http2=“true” read-timeout=“30000”
I do not have Apache/NGINX running on this Ubuntu Server. Also I should mention that I can get to ip:8080/auth from a Windows Server (up in AWS VPC) that I use to test URLs.
What the heck am I missing that this thing doesn’t wanna fwd correctly?
I have made a Route 53 DNS Records called keycloak.domain.com that points to the AWS ALB but that doesn’t work with keycloak.domain.com/auth and neither does the ALB DNS Record so I KNOW I’m definitely missing something.
Please help
