I’m going to change the client adapters of my custom apps from CAS protocol to OIDC protocol.
CAS protocol has an interesting feature that can check if a user is logged or not without blocking the service call.
This feature is activated redirecting the user to IDP with a parameter gateway=true: if the user is already logged than return with the token, if the user is not logged then no token is returned to the service.
https://apereo.atlassian.net/wiki/spaces/CAS/pages/102926870/gateway
If I want to preserve the same behaviour with the OIDC protocol I have to configure the browser flow with a custom Authenticator? Maybe something that check the gateway request parameter and redirect back to the service before showing the login form?
Thanks
