I’m using standalone Keycloak with a SQL-Server DB. My DB is configured via KeycloakDSdatasource in standalone.xml.
Next to it is a preconfigured datasource ExampleDS. The name indidcates, that this is an template, but when i delete it Keycloak doesn’t start anymore:
ERROR [org.jboss.as.controller.management-operation] (Controller Boot Thread) WFLYCTL0013: Operation (“add”) failed - address: ([(“deployment” => “keycloak-server.war”)]) - failure description: {
“WFLYCTL0412: Required services that are not installed:” => [“jboss.naming.context.java.jboss.datasources.ExampleDS”],
“WFLYCTL0180: Services with missing/unavailable dependencies” => [“jboss.naming.context.java.module.auth.auth.DefaultDataSource is missing [jboss.naming.context.java.jboss.datasources.ExampleDS]”]
This datasource is referenced in subsystem xmlns=“urn:jboss:domain:ee:5.0”.
So, what’s the job of this datasource? How to remove it?
