I can’t seem to run the docker container (neither what’s in the described in the docs, nor latest). I’m on macOS. Trying
docker run -p 8080:8080 -e KEYCLOAK_USER=admin -e KEYCLOAK_PASSWORD=admin quay.io/keycloak/keycloak
and
docker run -p 8080:8080 -e KEYCLOAK_USER=admin -e KEYCLOAK_PASSWORD=admin quay.io/keycloak/keycloak:12.0.4
The error I see is:
21:12:50,176 INFO [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (ServerService Thread Pool -- 65) Node name: 632574ad6e09, Site name: null
21:13:20,710 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool -- 65) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1322)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
at org.jboss.as.connector@21.0.2.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:371)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
at org.keycloak.keycloak-server-spi-private@12.0.4//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:654)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:136)
at org.keycloak.keycloak-server-spi-private@12.0.4//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:228)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:129)
at org.keycloak.keycloak-wildfly-extensions@12.0.4//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:29)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:115)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2815)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:371)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:283)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:93)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: java.sql.SQLNonTransientConnectionException: Could not connect to address=(host=mariadb)(port=3306)(type=master) : Socket fail to connect to host:mariadb, port:3306. connect timed out
at org.mariadb.jdbc//org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.get(ExceptionMapper.java:241)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1243)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.util.Utils.retrieveProxy(Utils.java:622)
at org.mariadb.jdbc//org.mariadb.jdbc.MariaDbConnection.newConnection(MariaDbConnection.java:142)
at org.mariadb.jdbc//org.mariadb.jdbc.Driver.connect(Driver.java:86)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
... 57 more
Caused by: java.sql.SQLNonTransientConnectionException: Socket fail to connect to host:mariadb, port:3306. connect timed out
at org.mariadb.jdbc//org.mariadb.jdbc.internal.util.exceptions.ExceptionMapper.connException(ExceptionMapper.java:87)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:218)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createConnection(AbstractConnectProtocol.java:474)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.connectWithoutProxy(AbstractConnectProtocol.java:1238)
... 61 more
Caused by: java.net.SocketTimeoutException: connect timed out
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method)
at java.base/java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399)
at java.base/java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242)
at java.base/java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.base/java.net.Socket.connect(Socket.java:609)
at org.mariadb.jdbc//org.mariadb.jdbc.internal.protocol.AbstractConnectProtocol.createSocket(AbstractConnectProtocol.java:213)
... 63 more
21:13:20,717 FATAL [org.keycloak.services] (ServerService Thread Pool -- 65) Error during startup: java.lang.RuntimeException: Failed to connect to database
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:377)
Caused by: java.sql.SQLException: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:159)
... 45 more
Caused by: javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:690)
... 47 more
Caused by: javax.resource.ResourceException: IJ031084: Unable to create connection
... 50 more
... 57 more
... 61 more
... 63 more
