Hi, guys, Keycloak works well while I am using H2 database. But I want to switch to using Firebird as database.
So, I have the following path D:\Keycloak\modules\system\layers\keycloak\org\firebirdsql\main, where is jaybird-3.0.9.jar and its module.xml
<module xmlns="urn:jboss:module:1.3" name="org.firebirdsql">
<resources>
<resource-root path="jaybird-3.0.9.jar"/>
</resources>
<dependencies>
<module name="javax.api"/>
<module name="javax.transaction.api"/>
<module name="javax.resource.api"/>
</dependencies>
</module>
So, Iâve changed standalone.xml:
<datasources>
<datasource jndi-name="java:jboss/datasources/ExampleDS" pool-name="ExampleDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:h2:mem:test;DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE</connection-url>
<driver>h2</driver>
<security>
<user-name>sa</user-name>
<password>sa</password>
</security>
</datasource>
<datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<connection-url>jdbc:firebirdsql://localhost:3050/D:\KeycloakDB\KeycloakDB.FDB</connection-url>
<driver>firebirdsql</driver>
<security>
<user-name>SYSDBA</user-name>
<password>masterkey</password>
</security>
</datasource>
<drivers>
<driver name="h2" module="com.h2database.h2">
<xa-datasource-class>org.h2.jdbcx.JdbcDataSource</xa-datasource-class>
</driver>
<driver name="firebirdsql" module="org.firebirdsql">
<driver-class>org.firebirdsql.jdbc.FBDriver</driver-class>
</driver>
</drivers>
</datasources>
But this doesnât work for me. While starting Keycloak, I get many consecutive error messages, starting with this one:
11:54:20,709 FATAL [org.keycloak.services] (ServerService Thread Pool -- 68) Error during startup: java.lang.RuntimeException: Exception invoking method [listUnrunChangeSets] on object [liquibase.Liquibase@5163cec2], using arguments [null,(),false]
The question is what am I doing wrong? Please help me with this. Thank you.
