Can't use JDBC_PING when using Oracle database
Hi, we use Keycloak with Oracle database. Because we run 2 clusters “dev” and “staging” in the same network, so we have to use JDBC_PING to separate those clusters, but we got this error:
"Caused by: Error : 942, Position : 46, Sql = SELECT ping_data, own_addr, cluster_name FROM JGROUPSPING WHERE cluster_name=:1 , OriginalSql = SELECT ping_data, own_addr, cluster_name FROM JGROUPSPING WHERE cluster_name=?, Error Msg = ORA-00942: table or view does not exist
	at com.oracle.jdbc@12.2.0.1.0//oracle.jdbc.driver.t4cttioer11.processerror(t4cttioer11.java:498)
	... 32 more
09:49:04,949 ERROR [org.jgroups.protocols.JDBC_PING] (thread-7,ejb,iam-keycloak-dev-65c4b888c9-n97j7) JGRP000145: Error updating JDBC_PING table: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist"
Seem like the table does not exist, please advise if there is any solution for my case.
Thanks for your help!
