Certificate mTLS failed after some days running
I have certificate authentication everything works fine, but I have this error happens after keycloak running after days working. Someone already seem this type of error?
keycloak-0 keycloak 14:30:50,128 INFO  [org.keycloak.services.x509.NginxProxySslClientCertificateLookup] (default task-9748) Impossible to rebuild end user cert chain : client certificate authentication will fail.
keycloak-0 keycloak 14:30:50,258 ERROR [org.keycloak.services] (default task-9748) Not possible to verify signature on CRL. X509 certificate doesn't have CA chain available on it: java.security.GeneralSecurityException: Not possible to verify signature on CRL. X509 certificate doesn't have CA chain available on it
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.utils.CRLUtils.check(CRLUtils.java:116)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.authenticators.x509.CertificateValidator.checkRevocationStatusUsingCRL(CertificateValidator.java:750)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.authenticators.x509.CertificateValidator.checkRevocationStatus(CertificateValidator.java:783)
keycloak-0 keycloak 	at deployment.auth-cert-flow.jar//package.keycloak.auth.ValidateX509CertificateUsername.authenticate(ValidateX509CertificateUsername.java:54)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:446)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.DefaultAuthenticationFlow.processFlow(DefaultAuthenticationFlow.java:253)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.DefaultAuthenticationFlow.processSingleFlowExecutionModel(DefaultAuthenticationFlow.java:389)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.authentication.AuthenticationProcessor.authenticateOnly(AuthenticationProcessor.java:990)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.resourceOwnerPasswordCredentialsGrant(TokenEndpoint.java:663)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:203)
keycloak-0 keycloak 	at jdk.internal.reflect.GeneratedMethodAccessor458.invoke(Unknown Source)
keycloak-0 keycloak 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
keycloak-0 keycloak 	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:546)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:435)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:396)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:398)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:365)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:110)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:141)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
keycloak-0 keycloak 	at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
keycloak-0 keycloak 	at javax.servlet.api@2.0.0.Final//javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
keycloak-0 keycloak 	at org.keycloak.keycloak-wildfly-extensions@15.1.1//org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
keycloak-0 keycloak 	at org.keycloak.keycloak-services@15.1.1//org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
keycloak-0 keycloak 	at org.keycloak.keycloak-wildfly-extensions@15.1.1//org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
keycloak-0 keycloak 	at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
keycloak-0 keycloak 	at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
keycloak-0 keycloak 	at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
keycloak-0 keycloak 	at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
keycloak-0 keycloak 	at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
keycloak-0 keycloak 	at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:387)
keycloak-0 keycloak 	at io.undertow.core@2.2.5.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:841)
keycloak-0 keycloak 	at org.jboss.threads@2.4.0.Final//org.jboss.threads.ContextClassLoaderSavingRunnable.run(ContextClassLoaderSavingRunnable.java:35)
keycloak-0 keycloak 	at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1990)
keycloak-0 keycloak 	at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
keycloak-0 keycloak 	at org.jboss.threads@2.4.0.Final//org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
keycloak-0 keycloak 	at org.jboss.xnio@3.8.4.Final//org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280)
keycloak-0 keycloak 	at java.base/java.lang.Thread.run(Thread.java:829)
keycloak-0 keycloak
keycloak-0 keycloak 14:30:50,258 WARN  [org.keycloak.services] (Brute Force Protector) KC-SERVICES0053: login failure for user f:614c6764-d27e-4104-987b-71386ba0b3b1:58392440900 from ip 2804:14c:8783:8e5f:dc44:ec5c:6a4f:79e8
How your client CA chain looks like and what is expiry date for each CA in that chain?
There a root ca and an intermediate certificates imported into keycloak chain, and the expiry date is very long, and this problems happens after a long time with keycloak running, it’s look like that keycloak lost reference at this certificate chains.
It mentions the CRL (certificate revocation list) could not be checked. Please check if the CRL is accessible.
