The occasion
Spring Security just made an interesting change to their OAuth2 Client.
https://github.com/spring-projects/spring-security/issues/9610
For years they have used regular old Basic Authentication for confidential Token Requests, instead of the pre-URL-encoded variation the OAuth2-Spec describes.
https://datatracker.ietf.org/doc/html/rfc6749#section-2.3.1
I personally wasn’t even aware that OAuth2 uses a modified Basic Auth variant.
So, I thought I’ll have a look what Keycloak does and did a quick check with Postman.
The setup
Create a confidential client with.
- client_id: local+test
- client_secret: 9b51491b-b4be-4272-b72a-3a76805d5154
Manually do Authorization Code Flow.
The result
- Token request with test+local:9b51491b-b4be-4272-b72a-3a76805d5154 succeeds
- Token request with test%2Blocal:9b51491b-b4be-4272-b72a-3a76805d5154 fails (invalid client credentials)
The interpretation
So naturally one would come to the conclusion that Keycloak uses regular old Basic Auth, instead of the in the OAuth Spec described variation.
Now this will in most cases not be relevant, as UUIDs aren’t subject to any changes from URL encoding & people will in most cases not choose clientIDs with special characters in them.
The question
- Is my conclusion on the Basic Auth Protocol valid?
- Does the Keycloak Team intend to address the Basic Auth Protocol for Client Authentication at some point, or is your stand: Don’t use special characters?
