I have 2 separate installations of Keycloak, using a nearly identical setup. One is for testing, the other for production.
Both have a Client using openid-connect
with confidential
Access Type, with “Service Accounts Enabled” and “Authorization Enabled”. Both have the “Assigned Default Client Scopes” aaa
and bbb
When I generate an access token for one of them, the response contains "scope":"aaa bbb"
, while the other gets "scope":"bbb aaa"
curl \
-d "client_id=myid" \
-d "client_secret=mysecret" \
-d "grant_type=client_credentials" \
"https://mykc/auth/realms/myrealm/protocol/openid-connect/token"
What could be affecting the order of these Client Scopes? I tried removing one of the scopes and adding it again, and did the same for the second scope - nothing seems to affect their order. The Clients were both created the same way.
