In the realm settings, under token tab , i am trying to set
Client Session Idle
Client Session Max
so that i can show session timeout in my application based upon the time i set in above field.
But even after giving Client Session Idle and Client Session Idle time , i am not getting signout automatically.
It is always taking time mentioned in “SSO Session Max” to sign out the user.
below are the timing i have mentioned – -
Client Session Idle - 3min
Client Session Max - 5min
SSO Session Max - 10min
the application is getting logout after 10min and not 5min irrespective of the user activity.
In the keycloak documentation , it is mentioned that it will take value mentioned in Client Session Max if SSO Session Max value is not mentioned.
What i need to implement is to show a popup when session timeout to the user so that if they want to stay in the application they can do that.
