I am working on a customized EventListenerProvider. In this provider, I need to call method:
ClientModel.addClientScope()
to add a clientScope to a client.
However, I found it doesn’t work even the method is called. I didn’t see any error in log, just doesn’t work.
ClientModel is an interface, so I guess it is because I didn’t add the proper jar into my project then there is no proper class implementation for this interface.
Then I checked in keycloak service, and see several implementation. Then I try to add all these jar as dependency into my project
<artifactId>keycloak-model-jpa</artifactId>
<artifactId>keycloak-model-infinispan</artifactId>
<artifactId>keycloak-model-map</artifactId>
<artifactId>keycloak-server-spi-private</artifactId>
But the new provider build with the above dependency still doesn’t work.
Anyone has idea which dependency I should add in order to make the method ClientModel.addClientScope()
works ? Or did I miss something else ?
Thanks
