Trying to connect Keycloak database to user created schema. An error occured with the following exception.
02:53:07,349 INFO [org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory] (ServerService Thread Pool -- 58) Database info: {databaseUrl=jdbc:postgresql://postgres:5432/keycloak_dashbord_db, databaseUser=fc_db_user, databaseProduct=PostgreSQL 13.2, databaseDriver=PostgreSQL JDBC Driver 42.2.5}
02:53:12,475 INFO [org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider] (ServerService Thread Pool -- 58) Initializing database schema. Using changelog META-INF/jpa-changelog-master.xml
02:53:29,181 ERROR [org.keycloak.connections.jpa.updater.liquibase.conn.DefaultLiquibaseConnectionProvider] (ServerService Thread Pool -- 58) Change Set META-INF/jpa-changelog-13.0.0.xml::json-string-accomodation::keycloak failed. Error: ERROR: relation "realm_attribute" does not exist
Position: 8 [Failed SQL: UPDATE REALM_ATTRIBUTE SET VALUE_NEW = VALUE, VALUE = NULL]
02:53:29,181 ERROR [org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider] (ServerService Thread Pool -- 58) Error has occurred while updating the database: liquibase.exception.MigrationFailedException: Migration failed for change set META-INF/jpa-changelog-13.0.0.xml::json-string-accomodation::keycloak:
Reason: liquibase.exception.DatabaseException: ERROR: relation "realm_attribute" does not exist
at org.liquibase//liquibase.changelog.ChangeSet.execute(ChangeSet.java:619)
at org.liquibase//liquibase.changelog.visitor.UpdateVisitor.visit(UpdateVisitor.java:51)
at org.liquibase//liquibase.changelog.ChangeLogIterator.run(ChangeLogIterator.java:79)
at org.liquibase//liquibase.Liquibase.update(Liquibase.java:214)
at org.liquibase//liquibase.Liquibase.update(Liquibase.java:192)
at org.liquibase//liquibase.Liquibase.update(Liquibase.java:188)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.updateChangeSet(LiquibaseJpaUpdaterProvider.java:184)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:103)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:82)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory$2.run(DefaultJpaConnectionProviderFactory.java:354)
at org.keycloak.keycloak-server-spi-private@13.0.0//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:250)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.update(DefaultJpaConnectionProviderFactory.java:347)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.migration(DefaultJpaConnectionProviderFactory.java:319)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lambda$lazyInit$0(DefaultJpaConnectionProviderFactory.java:183)
at org.keycloak.keycloak-server-spi-private@13.0.0//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:771)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.lazyInit(DefaultJpaConnectionProviderFactory.java:134)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:82)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.create(DefaultJpaConnectionProviderFactory.java:60)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.DefaultKeycloakSession.getProvider(DefaultKeycloakSession.java:315)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:63)
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.models.jpa.JpaRealmProviderFactory.create(JpaRealmProviderFactory.java:39)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.DefaultKeycloakSession.realmLocalStorage(DefaultKeycloakSession.java:227)
at org.keycloak.keycloak-model-infinispan@13.0.0//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealmDelegate(RealmCacheSession.java:149)
at org.keycloak.keycloak-model-infinispan@13.0.0//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealm(RealmCacheSession.java:411)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.managers.ApplianceBootstrap.isNewInstall(ApplianceBootstrap.java:46)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.resources.KeycloakApplication$2.run(KeycloakApplication.java:180)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.resources.KeycloakApplication.bootstrap(KeycloakApplication.java:155)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:124)
at org.keycloak.keycloak-wildfly-extensions@13.0.0//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:36)
at org.keycloak.keycloak-services@13.0.0//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:112)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2835)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:376)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:288)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:98)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
Caused by: liquibase.exception.DatabaseException: ERROR: relation "realm_attribute" does not exist
at org.liquibase//liquibase.executor.jvm.JdbcExecutor$ExecuteStatementCallback.doInStatement(JdbcExecutor.java:309)
at org.liquibase//liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:55)
at org.liquibase//liquibase.executor.jvm.JdbcExecutor.execute(JdbcExecutor.java:113)
at org.liquibase//liquibase.database.AbstractJdbcDatabase.execute(AbstractJdbcDatabase.java:1277)
at org.liquibase//liquibase.database.AbstractJdbcDatabase.executeStatements(AbstractJdbcDatabase.java:1259)
at org.liquibase//liquibase.changelog.ChangeSet.execute(ChangeSet.java:582)
... 67 more
Caused by: org.postgresql.util.PSQLException: ERROR: relation "realm_attribute" does not exist
Position: 8
at org.postgresql.jdbc@42.2.5//org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2440)
at org.postgresql.jdbc@42.2.5//org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2183)
at org.postgresql.jdbc@42.2.5//org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:308)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:441)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.execute(PgStatement.java:365)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:307)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.executeCachedSql(PgStatement.java:293)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.executeWithFlags(PgStatement.java:270)
at org.postgresql.jdbc@42.2.5//org.postgresql.jdbc.PgStatement.execute(PgStatement.java:266)
at org.jboss.ironjacamar.jdbcadapters@1.4.27.Final//org.jboss.jca.adapters.jdbc.WrappedStatement.execute(WrappedStatement.java:198)
at org.liquibase//liquibase.executor.jvm.JdbcExecutor$ExecuteStatementCallback.doInStatement(JdbcExecutor.java:307)
... 72 more
02:53:29,199 FATAL [org.keycloak.services] (ServerService Thread Pool -- 58) Error during startup: java.lang.RuntimeException: Failed to update database
at org.keycloak.keycloak-model-jpa@13.0.0//org.keycloak.connections.jpa.updater.liquibase.LiquibaseJpaUpdaterProvider.update(LiquibaseJpaUpdaterProvider.java:118)
Caused by: liquibase.exception.MigrationFailedException: Migration failed for change set META-INF/jpa-changelog-13.0.0.xml::json-string-accomodation::keycloak:
... 60 more
... 67 more
Position: 8
... 72 more
Here are my docker-compose
file. Postgres default schema are created by sql init script.
keycloak:
container_name: keycloak_demo
image: jboss/keycloak:13.0.0
environment:
DB_VENDOR: POSTGRES
DB_ADDR: postgres
DB_SCHEMA: keycloak_schema
DB_DATABASE: keycloak_dashbord_db
DB_USER: db_user
DB_PASSWORD: db_pass
KEYCLOAK_FRONTEND_URL: 'http://localhost:8080/auth/'
KEYCLOAK_USER: admin
KEYCLOAK_PASSWORD: admin
ports:
- 8080:8080
depends_on:
- postgres
networks:
- keycloak-dev-net
postgres:
container_name: keycloak_postgres
image: postgres:13-alpine
volumes:
- keycloak_postgres_data:/var/lib/postgresql/data
- ./create_schema.sql:/docker-entrypoint-initdb.d/create_schema.sql
environment:
POSTGRES_DB: keycloak_db
POSTGRES_USER: db_user
POSTGRES_PASSWORD: db_pass
ports:
- "5432:5432"
networks:
- keycloak-dev-net
I have checked with default public schema. It works perfectly.
