Connecting to AWS Aurora MySql
Hi, I’m attempting to run Keycloak in Kubernetes, and the backend I’m using is Aurora MySQL. I’m getting DB connection failures anytime I try to connect to MySql Aurora, which is odd. However, with RDS MySQL running, everything is good. I’ve attached the log to this message. It would be very appreciated if anyone could assist in resolving this problem.
 2021-12-10 21:43:50,196 WARN  [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool -- 64) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
        at org.jboss.ironjacamar.jdbcadapters@1.4.27.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
        at org.jboss.ironjacamar.jdbcadapters@1.4.27.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
        at org.jboss.ironjacamar.jdbcadapters@1.4.27.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1322)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
        at org.jboss.ironjacamar.impl@1.4.27.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
        at org.jboss.ironjacamar.jdbcadapters@1.4.27.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
        at org.jboss.as.connector@23.0.2.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
        at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:385)
        at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
        at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
        at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:758)
        at org.keycloak.keycloak-model-jpa@15.0.2//org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
        at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:134)
        at org.keycloak.keycloak-server-spi-private@15.0.2//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:250)
        at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:128)
        at org.keycloak.keycloak-wildfly-extensions@15.0.2//org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:36)
        at org.keycloak.keycloak-services@15.0.2//org.keycloak.services.resources.KeycloakApplication.<init>(KeycloakApplication.java:114)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2835)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:376)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:288)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:98)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:140)
        at org.jboss.resteasy.resteasy-jaxrs@3.15.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:42)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
        at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:588)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:559)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
        at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
        at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
        at io.undertow.servlet@2.2.5.Final//io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:601)
        at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
        at org.wildfly.extension.undertow@23.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
        at org.jboss.threads@2.4.0.Final//org.jboss.threads.JBossThread.run(JBossThread.java:513)
    Caused by: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
Apologies. It’s working fine with Aurora MySQL version 8.0.mysql_aurora.3.01.0
