I have a realm on a server and I have configured this realm to my requirements. Now I want to copy this realm on the same server. I klick on “Export” and a JSON file is created. I change the realm name in the file and remove all ids in the file to not get duplicate key exception and then I Import the file again. It works.
My question:
Is there any easier way to export and import realms on the same server?
Is it ok to manipulate the JSON file manually. Are there any pitfalls? What else do I have to modify in the JSON file to not run into trouble?
Best regards
Tobias
