2023-05-28 17:41:53,478 ERROR [org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider] (executor-thread-58) Failed to make identity provider oauth callback: org.keycloak.broker.provider.IdentityBrokerException: Could not fetch attributes from userinfo endpoint.
at org.keycloak.broker.oidc.OIDCIdentityProvider.getFederatedIdentity(OIDCIdentityProvider.java:405)
at org.keycloak.broker.oidc.AbstractOAuth2IdentityProvider$Endpoint.authResponse(AbstractOAuth2IdentityProvider.java:505)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.RuntimeException: Unsupported content-type [text/html; charset=UTF-8] in response from [http://192.168.30.55:8000/osspid-client/oauth2/userInfo].
at org.keycloak.broker.oidc.OIDCIdentityProvider.extractIdentity(OIDCIdentityProvider.java:474)
at org.keycloak.broker.oidc.OIDCIdentityProvider.getFederatedIdentity(OIDCIdentityProvider.java:386)
… 49 more
2023-05-28 17:41:53,480 WARN [org.keycloak.events] (executor-thread-58) type=IDENTITY_PROVIDER_LOGIN_ERROR, realmId=c55d08ae-6a10-4e35-8084-45849bce35cb, clientId=account-console, userId=null, ipAddress=172.17.0.1, error=identity_provider_login_failure, code_id=f859bcff-290c-4d04-b50a-a0b358c84b5c
