I want to create (with java code) a list of policies, one policy for each client-role in a list.
For each role, I search for the policy “role_[rolename]” and if it not exists, i’m going to create a new policy.
PoliciesResource polRes = authResource.policies();
try {
for(String roleName : roleNames){
PolicyRepresentation policy = polRes.findByName("role_"+roleName);
if(policy == null){
LOG.log(Level.INFO, "Per il ruolo {0} non esiste la policy. Creo la policy ruolo_{0}", roleName);
policy = new PolicyRepresentation();
policy.setName("role_"+nomeRuolo);
policy.setDescription("Il ruolo è "+roleName);
policy.setType("role");
Map<String, String> conf = new HashMap<>();
conf.put("roles", "[\""+roleName+"\"]");
policy.setConfig(conf);
policy.setLogic(Logic.POSITIVE);
Response response = polRes.create(policy);
switch(response.getStatus()){
case 200:
LOG.log(Level.INFO, "Creata la policy {0}", policy.getName());
break;
case 500:
LOG.log(Level.SEVERE, "Errore nella creazione della policy {0}", roleName);
LOG.log(Level.SEVERE, "Messaggio di errore con codice 500 : ",response.getStatusInfo().getReasonPhrase());
break;
default :
LOG.log(Level.SEVERE, "Errore nella creazione della policy {0}", policy.getName());
LOG.log(Level.SEVERE, "Messaggio di errore : ",response.getStatusInfo().getReasonPhrase());
response.close();
} catch (NotFoundException e) {
KeycloakUtility.logoutkeycloak(config, keycloak);
throw new Exception(e);
I’ll get a 500 error in the response. I’am trying to set the correct values in the policy, but what are the correct values?
In the documentation there is no hint how what type could be and what the map config could contains.
