TLDR: new ldap-mapper is deployed, but not showing up Situation:
I get Users from LDAP, where the username contains information that should be in an attribute,
Example : Doe,John ( Developer )
Here, developer should end up in an attribute “profession”.
They are registered with
/META-INF/services/
org.keycloak.storage.ldap.mappers.AbstractLDAPStorageMapper
and …/org.keycloak.storage.ldap.mappers.AbstractLDAPStorageMapperFactory
pointing to the created classes.
Keycloak log tells me the jar is deployed sucessfully, when debugging, the new mapper is not loaded in loadFactories.
I have tried copying an existent mapper, but to no avail.
Does someone know a mistake i made?
Do i need to Implement a specific interface oder extend another class?
I’m open for advice and comments, thank you in advance!
I also have this issue I see [org.jboss.as.server.deployment] (MSC service thread 1-8) WFLYSRV0027: Starting deployment of "mapper-jar-with-dependencies.jar" (runtime-name: "mapper-jar-with-dependencies.jar")
and [org.keycloak.subsystem.server.extension.KeycloakProviderDeploymentProcessor] (MSC service thread 1-2) Deploying Keycloak provider: mapper-jar-with-dependencies.jar
Since I stumbled upon this discussion with the same issue and nothing in here solved my problem, I want to point out that you should register your service with the Interface, not the AbstractClass. So your META-INF folder should contain a file named org.keycloak.storage.ldap.mappers.LDAPStorageMapperFactory pointing to your implementation of AbstractLDAPStorageMapperFactory.
