hi thanks for the answer, i just fiddled with it a bit and you did got me the solution,
it was pointing to 8088 instead of 8080 for me, and i was expecting the admin pluggin to be installed on /auth/admin/realms//customs but it’s /auth/realms/
thanks for the project I would have never figured it out otherwise.
i get an error when trying to use the test tough but that’s ok I might just need a dependency or something.
Also when you have errors like class not found when developing extensions it’s possible you need to declare some modules global and/or dependencies you need.
Take a look at the other readme’s for the other examples, especially the Keycloak config and global-modules examples.
