I am working on enabling MFA using TOTP on keycloak.
2FA with Google Authenticator work very well, but once a QR code is scanned, its saved as <realm_name>(username) in the Google Authenticator. This poses as a blocker incase I try scanning Keycloak present on multiple systems having same realm and username. For every scan of new QR code if the realm name and username is same then the Google Authenticator replaces the previous instance of TOTP.
Is there a way wherein I could configure Keycloak to return a user specified string and username through QR code instead of default <realm_name>(username), so that same Google Authenticator application can be used to scan QR code from multiple systems all having same usernames and realms configured over them.
