I am using a docker compose file to spin up the different service instances for the project I am working on, including the redis, postgres (to be used by the app and keycloak), and keycloak servers, along with the base app itself. Unfortunately, when I bring it all up, keycloak is unable to find it’s database unless I set the database AND schema to public, which is not ideal.
the specific error is either
postgres_1 | 2020-08-22 06:21:37.473 UTC [33] FATAL: database "keycloak" does not exist
when I have the following in my docker-compose.yaml (showing only environment for brevity)
postgres:
environment:
- POSTGRES_DB=postgres
- POSTGRES_USER=admin
- POSTGRES_PASSWORD=password
- PGDATA=/var/lib/postgresql/data/pgdata
keycloak:
environment:
KEYCLOAK_USER: admin
KEYCLOAK_PASSWORD: password
DB_VENDOR: POSTGRES
DB_USER: admin
DB_PASSWORD: password
DB_DATABASE: keycloak
DB_SCHEMA: public #or 'keycloak'
DB_ADDR: postgres
and I get (repeated MANY times)
postgres_1 | 2020-08-22 06:44:11.015 UTC [34] ERROR: relation "keycloak.databasechangeloglock" does not exist at character 22
postgres_1 | 2020-08-22 06:44:11.015 UTC [34] STATEMENT: select count(*) from keycloak.databasechangeloglock
postgres_1 | 2020-08-22 06:44:11.022 UTC [34] ERROR: schema "keycloak" does not exist at character 14
postgres_1 | 2020-08-22 06:44:11.022 UTC [34] STATEMENT: CREATE TABLE keycloak.databasechangeloglock (ID INT NOT NULL, LOCKED BOOLEAN NOT NULL, LOCKGRANTED TIMESTAMP WITHOUT TIME ZONE, LOCKEDBY VARCHAR(255), CONSTRAINT PK_DATABASECHANGELOGLOCK PRIMARY KEY (ID))
keycloak_1 | 06:44:11,022 WARN [org.keycloak.connections.jpa.updater.liquibase.lock.CustomLockService] (ServerService Thread Pool -- 60) Failed to create lock table. Maybe other transaction created in the meantime. Retrying...
when I use
DB_DATABASE: public
DB_SCHEMA: keycloak
The former situation would be the most ideal, as I would like to be able to put the keycloak on it’s own database, but understanding why both situations are currently broken is important so that I can solve this problem in the future if it pops up again.
the entire docker-compse.yaml file should it be needed
version: "3"
services:
pollster: #the main app
image: "pollster"
ports:
- "4201:4201"
volumes:
- "./properties.compose.json:/properties.json"
depends_on:
- redis_wait
- postgres_wait
- keycloak_wait
redis:
image: "redis"
redis_wait:
image: dadarek/wait-for-dependencies
depends_on:
- redis
command: redis:6379
postgres:
image: "postgres"
ports:
- "5433:5432"
environment:
- POSTGRES_DB=public
volumes:
- "postgres_data:/var/lib/postgresql/data/pgdata"
#command: ["postgres", "-c", "log_statement=all"] #Log All Postgres Queries.
postgres_wait:
depends_on:
- postgres
command: postgres:5432
keycloak:
image: "jboss/keycloak"
depends_on:
- postgres_wait
ports:
- "8080:8080"
environment:
DB_VENDOR: POSTGRES
DB_USER: admin
DB_DATABASE: public
DB_SCHEMA: keycloak
DB_ADDR: postgres
volumes:
- "keycloak_data:/keycloak"
keycloak_wait:
depends_on:
- keycloak
command: keycloak:8080
volumes:
postgres_data:
driver: local
keycloak_data:
driver: local
