Hi there
I have Keycloak and mysql running in docker containers on my local. I’m attempting to use the Benchmarking tools (GitHub - keycloak/keycloak-benchmark) so we can fine tune settings. However, when I run the command to create a number of realms (say 200), I end up maxing out the connections to the database. It seems that the threads are not letting go of their connections (or re-using the ones it already has) and seem to be requesting new ones from the pool.
Below are my two docker container setups with Docker Compose
version: '3'
services:
mysql_keycloak:
container_name: mysql_keycloak
image: percona:5.7-centos
# see https://hub.docker.com/_/perconafor settings
environment:
- MYSQL_ALLOW_EMPTY_PASSWORD=1
- MYSQL_HOST=localhost
- DEV_MYSQL_USER=dev
- DEV_MYSQL_PASSWORD=@ch13v3rs
volumes:
- data:/var/lib/mysql
- ${PWD}/mysql/configuration/threading.cnf:/etc/percona-server.conf.d/threading.cnf
- ${PWD}/scripts/initialize-db.sh:/docker-entrypoint-initdb.d/initialize-db.sh
- ${PWD}/scripts/initial-database.sql:/scripts/initial-database.sql
ports:
- "33066:3306"
networks:
- test_network
keycloak:
container_name: keycloak
image: jboss/keycloak:latest
command: -b 0.0.0.0 -Dkeycloak.profile.feature.upload_scripts=enabled -Dkeycloak.profile.feature.admin_fine_grained_authz=enabled -Dkeycloak.profile.feature.token_exchange=enabled -Djboss.as.management.blocking.timeout=3600 -D
environment:
- DB_VENDOR=mysql
- DB_ADDR=mysql_keycloak
- DB_PORT=3306
- DB_USER=dev
- DB_PASSWORD=supersecretpassword
- KEYCLOAK_USER=admin
- KEYCLOAK_PASSWORD=admin
- KEYCLOAK_FRONTEND_URL=https://localhost:8443/auth/
- keycloak.profile.feature.upload_scripts=enabled
depends_on:
- mysql_keycloak
volumes:
- ${PWD}/deployments:/opt/jboss/keycloak/standalone/deployments
- ${PWD}/keycloak/configuration/standalone-ha.xml:/opt/jboss/keycloak/standalone/configuration/standalone-ha.xml
ports:
- "8443:8443"
networks:
- test_network
volumes:
data:
driver: local
dbdata:
driver: local
# you will need to update the network
networks:
test_network:
driver: bridge
external: true
This is the datasource entry for the standalone-ha.xml
<datasource jndi-name="java:jboss/datasources/KeycloakDS" pool-name="KeycloakDS" enabled="true" use-java-context="true" use-ccm="false">
<connection-url>jdbc:mysql://${env.DB_ADDR:mysql}:${env.DB_PORT:3306}/${env.DB_DATABASE:keycloak}${env.JDBC_PARAMS:}</connection-url>
<driver>mysql</driver>
<pool>
<flush-strategy>IdleConnections</flush-strategy>
<min-pool-size>1</min-pool-size>
<max-pool-size>1000</max-pool-size>
<initial-pool-size>20</initial-pool-size>
<use-strict-min>true</use-strict-min>
</pool>
<timeout>
<idle-timeout-minutes>1</idle-timeout-minutes>
</timeout>
<security>
<user-name>${env.DB_USER:keycloak}</user-name>
<password>${env.DB_PASSWORD:password}</password>
</security>
<validation>
<check-valid-connection-sql>SELECT 1</check-valid-connection-sql>
<background-validation>true</background-validation>
<background-validation-millis>6000</background-validation-millis>
</validation>
</datasource>
On the mysql side of things, this is the settings I have for the connection pools in the threading.cnf
file
[mysqld]
# Enable Thread Pooling
thread_handling=pool-of-threads
thread_pool_idle_timeout=30
thread_pool_size=20
max_connections=150
If we execute the REST end point for the dataset to create a number of realms and set that too 100 (https://localhost:8443/auth/realms/master/dataset/create-realms?count=100&clients-per-realm=10), it will create all 100 realms. Two minutes After the realms have all been created, I check on mysql to see how many connections are running show status where
variable_name = 'Threads_connected';
and it shows 100.
If I execute the REST call again, to create another 100 realms, it will get about 50 deep and then it will blow up. On the MySQL side of things, I get too many connection errors:
mysql_keycloak | 2021-03-09T20:54:49.747437Z 0 [Warning] Too many connections
mysql_keycloak | 2021-03-09T20:54:49.752921Z 0 [Warning] Too many connections
mysql_keycloak | 2021-03-09T20:54:49.755953Z 0 [Warning] Too many connections
On the keycloak side, I get the following error message:
keycloak | 20:54:49,748 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (pool-20-thread-5) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
keycloak | at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
keycloak | at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
keycloak | at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1322)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getTransactionNewConnection(AbstractPool.java:714)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:613)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
keycloak | at org.jboss.ironjacamar.impl@1.4.23.Final//org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
keycloak | at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
keycloak | at org.jboss.as.connector@21.0.2.Final//org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.connections.internal.DatasourceConnectionProviderImpl.getConnection(DatasourceConnectionProviderImpl.java:122)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.internal.NonContextualJdbcConnectionAccess.obtainConnection(NonContextualJdbcConnectionAccess.java:35)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:106)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.getPhysicalConnection(LogicalConnectionManagedImpl.java:136)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl.connection(StatementPreparerImpl.java:50)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl$1.doPrepare(StatementPreparerImpl.java:90)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl$StatementPreparationTemplate.prepareStatement(StatementPreparerImpl.java:176)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl.prepareStatement(StatementPreparerImpl.java:81)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3173)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3706)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.action.internal.EntityInsertAction.execute(EntityInsertAction.java:90)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:604)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:478)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.event.internal.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:356)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:39)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.doFlush(SessionImpl.java:1472)
keycloak | at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1458)
keycloak | at jdk.internal.reflect.GeneratedMethodAccessor364.invoke(Unknown Source)
keycloak | at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
keycloak | at java.base/java.lang.reflect.Method.invoke(Method.java:566)
keycloak | at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.PersistenceExceptionConverter.invoke(PersistenceExceptionConverter.java:49)
keycloak | at javax.persistence.api@2.2.3//com.sun.proxy.$Proxy91.flush(Unknown Source)
keycloak | at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.models.jpa.JpaRealmProvider.createRealm(JpaRealmProvider.java:93)
keycloak | at org.keycloak.keycloak-model-infinispan@12.0.4//org.keycloak.models.cache.infinispan.RealmCacheSession.createRealm(RealmCacheSession.java:395)
keycloak | at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.managers.RealmManager.importRealm(RealmManager.java:516)
keycloak | at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.managers.RealmManager.importRealm(RealmManager.java:501)
keycloak | at deployment.keycloak-benchmark-dataset-0.4-SNAPSHOT.jar//org.keycloak.benchmark.dataset.DatasetResourceProvider.createAndSetRealm(DatasetResourceProvider.java:897)
keycloak | at deployment.keycloak-benchmark-dataset-0.4-SNAPSHOT.jar//org.keycloak.benchmark.dataset.DatasetResourceProvider.lambda$createRealmsImpl$2(DatasetResourceProvider.java:178)
keycloak | at org.keycloak.keycloak-server-spi-private@12.0.4//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:228)
keycloak | at org.keycloak.keycloak-server-spi-private@12.0.4//org.keycloak.models.utils.KeycloakModelUtils.runJobInTransactionWithTimeout(KeycloakModelUtils.java:268)
keycloak | at deployment.keycloak-benchmark-dataset-0.4-SNAPSHOT.jar//org.keycloak.benchmark.dataset.DatasetResourceProvider.lambda$createRealmsImpl$5(DatasetResourceProvider.java:177)
keycloak | at deployment.keycloak-benchmark-dataset-0.4-SNAPSHOT.jar//org.keycloak.benchmark.dataset.ExecutorHelper.lambda$addTask$0(ExecutorHelper.java:53)
keycloak | at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
keycloak | at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
keycloak | at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
keycloak | at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
keycloak | at java.base/java.lang.Thread.run(Thread.java:834)
keycloak | Caused by: java.sql.SQLNonTransientConnectionException: Data source rejected establishment of connection, message from server: "Too many connections"
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:110)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:836)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:456)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:246)
keycloak | at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:198)
keycloak | at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
keycloak | ... 50 more
keycloak |
keycloak | 20:54:49,750 WARN [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (pool-20-thread-5) SQL Error: 0, SQLState: null
keycloak | 20:54:49,750 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (pool-20-thread-5) javax.resource.ResourceException: IJ000453: Unable to get managed connection for java:jboss/datasources/KeycloakDS
Something else that comes up, regardless if I executed the REST end point to create another 100 realms and triggering the error, of if I just left at the inital 100 realms, the following warnings come up 5 mins after starting the initial request.
keycloak | 20:55:12,843 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:52 in state RUN
keycloak | 20:55:12,844 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:56 in state RUN
keycloak | 20:55:12,845 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:52
keycloak | 20:55:12,847 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:56
keycloak | 20:55:12,849 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:5c in state RUN
keycloak | 20:55:12,850 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:5c
keycloak | 20:55:12,854 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:66 in state RUN
keycloak | 20:55:12,855 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:66
keycloak | 20:55:14,037 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:7f in state RUN
keycloak | 20:55:14,039 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:7f
keycloak | 20:55:14,832 WARN [com.arjuna.ats.arjuna] (Transaction Reaper) ARJUNA012117: TransactionReaper::check timeout for TX 0:ffffac130003:15e6a115:6047df6f:a0 in state RUN
keycloak | 20:55:14,834 WARN [org.hibernate.resource.transaction.backend.jta.internal.synchronization.SynchronizationCallbackCoordinatorTrackingImpl] (Transaction Reaper Worker 0) HHH000451: Transaction afterCompletion called by a background thread; delaying afterCompletion processing until the original thread can handle it. [status=4]
keycloak | 20:55:14,834 WARN [com.arjuna.ats.arjuna] (Transaction Reaper Worker 0) ARJUNA012121: TransactionReaper::doCancellations worker Thread[Transaction Reaper Worker 0,5,main] successfully canceled TX 0:ffffac130003:15e6a115:6047df6f:a0
The about 1-2 mins after the warning messages, the DB connections start to be released and I can see the number go down when running show status where
I’m not 100% sure, but I don’t think the problem is on the dataset side of the code, cause it’s ultimately executing code in the main codebase to create the realms and the DB connections seem to be created and maintained in the main code base too. It seem like some sort of transaction is not completing properly and that the DB connection is never freed up.
I’m hoping this sort of bug is isolated to creating realms, but I’ll be creating other datasets soon. If it’s a more generic error, then this really doesn’t bode well when we’re expecting to see high traffic on the server. We’re looking to create 400-500 realms initially in production and are probably going to scale up to 1000 in the near future.
Is this something that can be fixed with a config change? I feel like I’ve tried everything already, but I might have missed something. If not and it is a bug, can we can a issue created for it?
Thanks
