We’re experiencing an issue which causes Keycloak server to stop serving requests and become unresponsive. The dependent services fail to initialize their keycloak adapters [2].
We pinpointed the issue to the following error in Keycloak logs (full stack trace in [4]):
ISPN000136: Error executing command LockControlCommand on Cache 'realmRevisions'
It looks as if there’s deadlock condition in handling realmRevisions cache supported by hard-coded pessimistic locking [1]. The realmRevisions is not configurable via standalone files, which makes it difficult to change the locking to OPTIMISTIC or adjust cache timeouts (a code change to core keycloak source code would be necessary).
We had partial success with switching the related ‘realms’ cache in standalone-ha.xml to OPTIMISTIC locking, <transaction mode="NON_XA" locking="OPTIMISTIC"/>
However this only caused the issue appear later in time (not within hours but within days since deployment).
This issue is currently a blocker of production rollout of Keycloak, and has high priority in our org. Any guidance on how to proceed would be extremely appreciated.
We’re running on Keycloak 8.0.1 which is deployed in Kubernetes, base image is [3].
Thank you,
Ondrej
[2] failure in dependent service:
2020-04-08 02:23:10,612 [default task-50] WARN org.keycloak.adapters.KeycloakDeployment - Failed to load URLs from [the-keycloak-host]/auth/realms/SMC/.well-known/openi
d-configuration
java.lang.Exception: Internal Server Error
at org.keycloak.adapters.KeycloakDeployment.getOidcConfiguration(KeycloakDeployment.java:221)
at org.keycloak.adapters.KeycloakDeployment.resolveUrls(KeycloakDeployment.java:178)
at org.keycloak.adapters.KeycloakDeployment.getAuthUrl(KeycloakDeployment.java:237)
at org.keycloak.adapters.OAuthRequestAuthenticator.getRedirectUri(OAuthRequestAuthenticator.java:175)
at org.keycloak.adapters.OAuthRequestAuthenticator.loginRedirect(OAuthRequestAuthenticator.java:213)
at org.keycloak.adapters.OAuthRequestAuthenticator.authenticate(OAuthRequestAuthenticator.java:275)
at org.keycloak.adapters.RequestAuthenticator.authenticate(RequestAuthenticator.java:138)
at org.keycloak.adapters.servlet.KeycloakOIDCFilter.doFilter(KeycloakOIDCFilter.java:195)
[4] Full stack trace:
06:43:28,462 ERROR [org.infinispan.interceptors.impl.InvocationContextInterceptor] (default task-1905) ISPN000136: Error executing command LockControlCommand on Cache 'realmRevisions', writing keys []: org.infinispan.util.concurrent.TimeoutException: ISPN000299: Unable to acquire lock after 10 seconds for key realm.query.by.name.SMC and requestor GlobalTx:local:978916. Lock is held by GlobalTx:local:978019
at org.infinispan@9.4.16.Final//org.infinispan.util.concurrent.locks.impl.DefaultLockManager$KeyAwareExtendedLockPromise.get(DefaultLockManager.java:288)
at org.infinispan@9.4.16.Final//org.infinispan.util.concurrent.locks.impl.DefaultLockManager$KeyAwareExtendedLockPromise.lock(DefaultLockManager.java:261)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.locking.PessimisticLockingInterceptor.localLockCommandWork(PessimisticLockingInterceptor.java:208)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.locking.PessimisticLockingInterceptor.visitLockControlCommand(PessimisticLockingInterceptor.java:187)
at org.infinispan@9.4.16.Final//org.infinispan.commands.control.LockControlCommand.acceptVisitor(LockControlCommand.java:117)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.BaseAsyncInterceptor.invokeNextAndHandle(BaseAsyncInterceptor.java:183)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.impl.TxInterceptor.visitLockControlCommand(TxInterceptor.java:223)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.BaseAsyncInterceptor.invokeNext(BaseAsyncInterceptor.java:54)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.DDAsyncInterceptor.handleDefault(DDAsyncInterceptor.java:54)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.DDAsyncInterceptor.visitLockControlCommand(DDAsyncInterceptor.java:160)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.BaseAsyncInterceptor.invokeNextAndExceptionally(BaseAsyncInterceptor.java:123)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.impl.InvocationContextInterceptor.visitCommand(InvocationContextInterceptor.java:90)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.BaseAsyncInterceptor.invokeNext(BaseAsyncInterceptor.java:56)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.impl.BatchingInterceptor.handleDefault(BatchingInterceptor.java:75)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.DDAsyncInterceptor.visitCommand(DDAsyncInterceptor.java:50)
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.impl.AsyncInterceptorChainImpl.invoke(AsyncInterceptorChainImpl.java:248)
at org.infinispan@9.4.16.Final//org.infinispan.cache.impl.CacheImpl.lock(CacheImpl.java:1077)
at org.infinispan@9.4.16.Final//org.infinispan.cache.impl.CacheImpl.lock(CacheImpl.java:1057)
at org.infinispan@9.4.16.Final//org.infinispan.cache.impl.AbstractDelegatingAdvancedCache.lock(AbstractDelegatingAdvancedCache.java:286)
at org.infinispan@9.4.16.Final//org.infinispan.cache.impl.EncoderCache.lock(EncoderCache.java:318)
at org.keycloak.keycloak-model-infinispan@8.0.1//org.keycloak.models.cache.infinispan.CacheManager.addRevisioned(CacheManager.java:147)
at org.keycloak.keycloak-model-infinispan@8.0.1//org.keycloak.models.cache.infinispan.CacheManager.addRevisioned(CacheManager.java:133)
at org.keycloak.keycloak-model-infinispan@8.0.1//org.keycloak.models.cache.infinispan.RealmCacheSession.getRealmByName(RealmCacheSession.java:439)
at org.keycloak.keycloak-services@8.0.1//org.keycloak.services.managers.RealmManager.getRealmByName(RealmManager.java:89)
at org.keycloak.keycloak-services@8.0.1//org.keycloak.services.resources.RealmsResource.init(RealmsResource.java:198)
at org.keycloak.keycloak-services@8.0.1//org.keycloak.services.resources.RealmsResource.getWellKnown(RealmsResource.java:246)
at jdk.internal.reflect.GeneratedMethodAccessor808.invoke(Unknown Source)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:517)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:406)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:370)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:356)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:372)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:344)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:317)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:227)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at org.jboss.resteasy.resteasy-jaxrs@3.9.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-services@8.0.1//org.keycloak.services.filters.KeycloakSessionServletFilter.doFilter(KeycloakSessionServletFilter.java:91)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.0.27.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.0.27.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@18.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1504)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.0.27.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.0.27.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:376)
at io.undertow.core@2.0.27.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
06:43:28,462 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1905) Uncaught server error: org.infinispan.util.concurrent.TimeoutException: ISPN000299: Unable to acquire lock after 10 seconds for key realm.query.by.name.SMC and requestor GlobalTx:local:978916. Lock is held by GlobalTx:local:978019
at org.infinispan@9.4.16.Final//org.infinispan.interceptors.impl.AsyncInterceptorChainImpl.invoke(AsyncInterceptorChainImpl.java:259)
