Hi Experts,
I am facing an issue where some realms fail to delete while running tests which are combination of multiple realm creation and deletion.
We are using Keycloak-4.7.0-final running in clustered mode. If someone already have came across this issue can suggest any best practises to follow or bad practise to avoid to take care this issue.
2020-07-28 00:19:51,691 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-103) Deadlock found when trying to get lock; try restarting transaction
2020-07-28 00:19:51,692 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-103) Uncaught server error: javax.persistence.OptimisticLockException: org.hibernate.exception.LockAcquisitionException: could not execute statement
at org.hibernate.internal.ExceptionConverterImpl.wrapLockException(ExceptionConverterImpl.java:277)
at org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:98)
at org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:181)
at org.hibernate.query.internal.AbstractProducedQuery.executeUpdate(AbstractProducedQuery.java:1604)
at org.keycloak.models.jpa.JpaUserProvider.preRemove(JpaUserProvider.java:376)
at org.keycloak.storage.UserStorageManager.preRemove(UserStorageManager.java:655)
at org.keycloak.models.cache.infinispan.UserCacheSession.preRemove(UserCacheSession.java:829)
at org.keycloak.models.jpa.JpaRealmProvider.removeRealm(JpaRealmProvider.java:140)
at org.keycloak.models.cache.infinispan.RealmCacheSession.removeRealm(RealmCacheSession.java:486)
Regards
Gaurav
