I have a custom domain-extension I deploy as a module, it all works fine.
Now I made a custom authenticator which uses the domain-extension for persisting data.
I have problem solving the dependendy to the domain-extension. The classloader cannot find the classes from the domain-extension.
Can anybody provide some help here.
Thanks Torsten
Solved:
I forgot the jboss-deployment-structure.xml as mentioned inthe documentation
