We’re trying to implement a custom registration flow. As part of that customization we need the ability to directly link to user registration. Our intent is to do some other things such as pre-populating fields based on a query param, but that’s not relevant to my question at hand (and I already have that working).
So far, I can’t find any way to directly link to the registration. Everything seems to require going through the combined login + registration page, which contains a button that has generated params that are required for the registration form to be rendered (specifically tab_id
). If I remove that param, it just redirects back to the login + registration page.
I see that this question has been asked numerous times in the past with no real solution given. I’m kind of blown away that this is seemingly so difficult to do, and it’s pretty discouraging TBH. Help?!
