Discourse, Keycloak, SAML - is it impossible to configure?
Hi!
I’ve been doing this for almost a week, but I can’t set it up! Tried a million options! Help me please…
So, there is a test instance of Keycloak, address - http://10.5.40.19:8081. There I made a realm CUBA and a SAML client:
Pic 2
As you can see from the screenshots, there is a test Discourse forum at https://cuba-test-forum-en.demo.haulmont.com/discuss
According to the discourse-saml plugin documentation, the URL for connecting to SSO in my test forum will be like this - https://cuba-test-forum-en.demo.haulmont.com/discuss/auth/saml/callback
SAML settings in app.yml file:
DISCOURSE_RELATIVE_URL_ROOT: /discuss
DISCOURSE_SAML_TITLE: "Example SAML"
DISCOURSE_SAML_TARGET_URL: "http://10.5.40.19:8081/auth/realms/CUBA/protocol/saml"
DISCOURSE_SAML_AUTO_CREATE_ACCOUNT: 1
DISCOURSE_SAML_CERT_FINGERPRINT: "0D:9A:46:68:6B:CA:A6:41:7A:F5:08:18:C4:01:47:33:75:AD:2C:EF"
DISCOURSE_SAML_CERT: "-----BEGIN CERTIFICATE-----
MIICmzCCAYMCBgF0wEV2uzANBgkqhkiG9w0BAQsFADARMQ8wDQYDVQQDDAZlbnNhbWwwHhcNMjAwOTI0MTMxODMxWhcNMzAwOTI0MTMyMDExWjARMQ8wDQYDVQQDDAZlbnNhbWwwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCclA1o6Q3jcpqpxHtx79nrDCBfUIHUhZP+4+wLlV+7nel7Kts5Tas6jSToeptueWxRLKadWtV5hN3ommGAN5/u61UXP1JX6c/vTkZZgS+xBO5wekCjZVnbOL2NA6n0PVq7//zinaqP6KsiUo8xKJKe1mrehVVpCUQW4a9rqzj8mTwE3t5t+X5GidvYDdqH075q47uTqO5WbiDJGPNH3qT8g07bzt5y3hTtu1aohCkAiChognRxVb1WDn35oC7Tn/1Hckbxie18tREXOha35Dq2jWAS5CyLf1pTHURpWS7JMp6cu8ZHE39hJpo6MKHkhtQgd9I6DBDoP1gTShU6eFCTAgMBAAEwDQYJKoZIhvcNAQELBQADggEBAAfJQNOygoL+Z16iLg8bA8l81Q/5VTmMFu2EKadefkHU611tZZm9D+5gug5RRHsaQn/NoL9gz1gDoUhBLgptklFHmiIIhGQmKdFeoNi5twIb6LFMe4ZhukWVlZuAfEHge0iE9M6/wQ54FYgQQ2aZjK+RnxBEaCRTxzJ/FzAjB/4Fp4DC2xQ8ceFdvnQoc8I+4K5SHIVqJdwKe44xIKLaLU/xKQcVeAe5drXPGOoDn4uBcrlDl6RstIIgkyIlp4RM0ofxOdUVj7PUo9NsxS9Zl9+MbHsydXTN8GhQFSoLW0zaXNFfAT0d7JJCR0QZAd9iP6YCJYBz3y5KjEeIREUUfTM=
-----END CERTIFICATE-----"
I took the certificate from here:
Pic 3
Exported it to PKCS12:
Pic 4
Imported it to KeyChain of my Macbook and exported it to PEM. In fact, it turned out the same, only with the words “BEGIN …” at the beginning and “END …” at the end.
When I try to log in using SAML, it sends me to the Keycloak page:
Pic 5
But there I see an error:
Unknown login requester
Pic 6
What am I doing wrong? I configured OpenID authorization, it works. But! For a number of reasons, I need to provide SAML as well.
Very much I ask for help!
Pic 2:
Pic 3:
Pic 4:
Pic 5:
Pic 6:
I apologize for such submission of material, but I am on this forum recently. Beginners cannot insert more than one picture in a message…
I will add. Keycloak is running in a Docker container. Here is the log of this container when switching to SAML from Discourse:
10:21:53,379 WARN  [org.keycloak.events] (default task-198) type=LOGIN_ERROR, realmId=CUBA, clientId=https://cuba-test-forum-en.demo.haulmont.com/discuss, userId=null, ipAddress=172.27.0.1, error=client_not_found
I changed the ClientID in Keycloak to the one defined in the logs:
Now in the Keycloak logs this error:
11:24:32,750 ERROR [org.keycloak.protocol.saml.SamlService] (default task-211) request validation failed: org.keycloak.common.VerificationException: SigAlg was null
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlProtocolUtils.verifyRedirectSignature(SamlProtocolUtils.java:137)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlProtocolUtils.verifyRedirectSignature(SamlProtocolUtils.java:127)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlService$RedirectBindingProtocol.verifySignature(SamlService.java:592)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlService$BindingProtocol.handleSamlRequest(SamlService.java:268)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlService$BindingProtocol.execute(SamlService.java:537)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.protocol.saml.SamlService.redirectBinding(SamlService.java:635)
	at jdk.internal.reflect.GeneratedMethodAccessor940.invoke(Unknown Source)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:543)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:432)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:393)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:395)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:364)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
	at org.jboss.resteasy.resteasy-jaxrs@3.12.1.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
	at org.keycloak.keycloak-wildfly-extensions@11.0.2//org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
	at org.keycloak.keycloak-services@11.0.2//org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
	at org.keycloak.keycloak-wildfly-extensions@11.0.2//org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
	at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
	at io.undertow.core@2.1.3.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
	at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
	at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
	at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
	at io.undertow.core@2.1.3.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
	at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
	at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
	at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
	at org.wildfly.extension.undertow@20.0.1.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
	at io.undertow.servlet@2.1.3.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
	at io.undertow.core@2.1.3.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:370)
	at io.undertow.core@2.1.3.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:830)
11:24:32,750 WARN  [org.keycloak.events] (default task-211) type=LOGIN_ERROR, realmId=CUBA, clientId=null, userId=null, ipAddress=172.27.0.1, error=invalid_signature
