Documentation (description) of realm roles?
I’m looking for the documentation of the default realm roles that we can assign to a client, such as:
“query-realms” “view-clients” “manage-realm” “manage-authorization”
I’m trying to understand what are the permissions associated to each of the possible roles.
Does anyone know if such documentation is available?
I’m not aware of anything that specifically documents each roles’ permissions. The official documentation just lists them: Server Administration Guide
However, it’s fairly safe (in most cases) that view-* allows you to “see” (i.e. GET) the Keycloak objects indicated by the role and manage-* allows you to “update” (i.e. POST, PUT, DELETE) the objects in the Admin UI and Admin API.
@xgp thanks for the reply.
I was trying to create a user and assign a realm role to the recently created user, via Rest API.
I had the client configured with permissions: manage-users, query-users and view-users.
I was able to create the user but not assign the realm role. It was giving a 403, even when trying to query the role (to get its id).
I’m now using realm-admin, which allows me to create the user and assign the role.
Maybe they could document these roles a bit better, to avoid people getting 403’s and not understanding why.
Thanks for your explanation.
Thanks for the detail. If you look in the code, it should work with the *-users roles you listed. Were you using the API method like this?
POST /admin/realms/{realm}/users/{userId}/role-mappings/clients/{clientId}
Thanks. I was stuck before that, when I was trying to get the role details:
GET /admin/realms/my-realm/roles/my-role-name
Hello
Updating this topic. It would me nice to have a very detailed documention
    view-realm
    view-users
    view-clients
    view-events
    manage-realm
    manage-users
    create-client
    manage-clients
    manage-events
    view-identity-providers
    manage-identity-providers
    impersonation
In my keycloak instance I have also role named
query-users
query-realms
query-groups
This is not in the documentation, is it deprecated and could be remove from realm-management client ?
It’s not deprecated, it’s being used by the admin API. Don’t remove these roles.
They are just not documented. :man_shrugging:
