I downloaded the latest jgroups-kubernetes jar
file from this website Maven Central Repository Search and placed it in in lib/lib/main
directory of Keycloak 17.0.0
This is my new cache-ispn-kube-ping.xml
file
<!-- custom stack goes into the jgroups element -->
<jgroups>
<stack name="kube-ping-tcp" extends="tcp">
<org.jgroups.protocols.kubernetes.KUBE_PING
namespace="default"
stack.combine="REPLACE"
stack.position="MPING" />
</stack>
</jgroups>
<!-- custom stack must be referenced by name in the stack attribute of the transport element -->
<transport lock-timeout="60000" stack="kube-ping-tcp"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<expiration lifespan="-1"/>
</distributed-cache>
<encoding>
</encoding>
</local-cache>
</replicated-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<encoding>
</encoding>
<memory max-count="-1"/>
</cache-container>
When I execute the command
kc.sh --verbose start-dev --cache=ispn --cache-config-file=cache-ispn-kube-ping.xml
I get the following exception ClassNotFoundException: org.jgroups.protocols.kubernetes.KUBE_PING
