Hi Guys, I’m looking for an example for Embedded Jetty or even better Spark Java
Fur sure I first googled for it but can’t find anything???
I’m using Spark Java as a standalone rest server
[Update]
Another guy asked the same question just a few days ago: https://stackoverflow.com/q/59355327/504184
Hi Mike,
Have you found a solution?
If so, could you please share a code snippet?
Thanks in advance.
Hi, no - I decided to switch over to Spring Boot or KTor ASAP. Guess Spark Java is dead…
Resource Server (RESTful API), Spring Boot, Spring Security, OAuth2, JWT, Keycloak: Flowable OAuth2 Resource Server
Also see:
