While building action-token-authenticator available in quickstarts I am getting below error.
(Windows 7 env)
Built using the command
mvn -Pwildfly-managed clean wildfly:deploy -Dkeycloak.management.port=10090
run:
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 06:24 min
[INFO] Finished at: 2019-12-11T10:20:35+05:30
[INFO] Final Memory: 62M/435M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.8:
run (install-adapters) on project provider-action-token-authenticator: An Ant Bu
ildException has occured: Execute failed: java.io.IOException: Cannot run progra
m “set nopause=true & call .\jboss-cli.bat” (in directory “D:\build_tools\KeyClo
ak\keycloak-8.0.1\keycloak-quickstarts-latest1\action-token-authenticator\target
\wildfly-14.0.1.Final\bin”): CreateProcess error=2, The system cannot find the f
ile specified
[ERROR] around Ant part …… @ 4:119 in D:
\build_tools\KeyCloak\keycloak-8.0.1\keycloak-quickstarts-latest1\action-token-a
uthenticator\target\antrun\build-run.xml
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionE
xception
D:\build_tools\KeyCloak\keycloak-8.0.1\keycloak-quickstarts-latest1\action-token
-authenticator>
