I’m trying to configure keycloak, instruction: https://medium.com/@hasnat.saeed/setup-keycloak-server-on-ubuntu-18-04-ed8c7c79a2d9
When I start standalone.sh, I receive following:
15:49:37,504 WARN [org.jboss.jca.core.connectionmanager.pool.strategy.OnePool] (ServerService Thread Pool – 66) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:345)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.getLocalManagedConnection(LocalManagedConnectionFactory.java:352)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createManagedConnection(LocalManagedConnectionFactory.java:287)
at org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.createConnectionEventListener(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:1328)
at org.jboss.jca.core.connectionmanager.pool.mcp.SemaphoreConcurrentLinkedDequeManagedConnectionPool.getConnection(SemaphoreConcurrentLinkedDequeManagedConnectionPool.java:499)
at org.jboss.jca.core.connectionmanager.pool.AbstractPool.getSimpleConnection(AbstractPool.java:632)
at org.jboss.jca.core.connectionmanager.pool.AbstractPool.getConnection(AbstractPool.java:604)
at org.jboss.jca.core.connectionmanager.AbstractConnectionManager.getManagedConnection(AbstractConnectionManager.java:624)
at org.jboss.jca.core.connectionmanager.tx.TxConnectionManagerImpl.getManagedConnection(TxConnectionManagerImpl.java:440)
at org.jboss.jca.core.connectionmanager.AbstractConnectionManager.allocateConnection(AbstractConnectionManager.java:789)
at org.jboss.jca.adapters.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:151)
at org.jboss.as.connector.subsystems.datasources.WildFlyDataSource.getConnection(WildFlyDataSource.java:64)
at org.keycloak.connections.jpa.DefaultJpaConnectionProviderFactory.getConnection(DefaultJpaConnectionProviderFactory.java:371)
at org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lazyInit(LiquibaseDBLockProvider.java:65)
at org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.lambda$waitForLock$2(LiquibaseDBLockProvider.java:96)
at org.keycloak.models.utils.KeycloakModelUtils.suspendJtaTransaction(KeycloakModelUtils.java:682)
at org.keycloak.connections.jpa.updater.liquibase.lock.LiquibaseDBLockProvider.waitForLock(LiquibaseDBLockProvider.java:94)
at org.keycloak.services.resources.KeycloakApplication$1.run(KeycloakApplication.java:143)
at org.keycloak.models.utils.KeycloakModelUtils.runJobInTransaction(KeycloakModelUtils.java:227)
at org.keycloak.services.resources.KeycloakApplication.startup(KeycloakApplication.java:136)
at org.keycloak.provider.wildfly.WildflyPlatform.onStartup(WildflyPlatform.java:29)
at org.keycloak.services.resources.KeycloakApplication.(KeycloakApplication.java:123)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at org.jboss.resteasy.core.ConstructorInjectorImpl.construct(ConstructorInjectorImpl.java:152)
at org.jboss.resteasy.spi.ResteasyProviderFactory.createProviderInstance(ResteasyProviderFactory.java:2784)
at org.jboss.resteasy.spi.ResteasyDeployment.createApplication(ResteasyDeployment.java:364)
at org.jboss.resteasy.spi.ResteasyDeployment.startInternal(ResteasyDeployment.java:277)
at org.jboss.resteasy.spi.ResteasyDeployment.start(ResteasyDeployment.java:89)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.init(ServletContainerDispatcher.java:119)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.init(HttpServletDispatcher.java:36)
at io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:117)
at org.wildfly.extension.undertow.security.RunAsLifecycleInterceptor.init(RunAsLifecycleInterceptor.java:78)
at io.undertow.servlet.core.LifecyleInterceptorInvocation.proceed(LifecyleInterceptorInvocation.java:103)
at io.undertow.servlet.core.ManagedServlet$DefaultInstanceStrategy.start(ManagedServlet.java:305)
at io.undertow.servlet.core.ManagedServlet.createServlet(ManagedServlet.java:145)
at io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:585)
at io.undertow.servlet.core.DeploymentManagerImpl$2.call(DeploymentManagerImpl.java:556)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:42)
at org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1504)
at io.undertow.servlet.core.DeploymentManagerImpl.start(DeploymentManagerImpl.java:598)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentService.startContext(UndertowDeploymentService.java:97)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentService$1.run(UndertowDeploymentService.java:78)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1982)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
at org.jboss.threads.JBossThread.run(JBossThread.java:485)
Caused by: org.h2.jdbc.JdbcSQLException: IO Exception: “java.net.UnknownHostException: 44-206-124-178-static.mgts.by: 44-206-124-178-static.mgts.by: Name or service not known” [90028-193]
at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
at org.h2.message.DbException.get(DbException.java:168)
at org.h2.message.DbException.convert(DbException.java:287)
at org.h2.util.NetUtils.getLocalAddress(NetUtils.java:273)
at org.h2.server.TcpServer.getURL(TcpServer.java:198)
at org.h2.tools.Server.start(Server.java:485)
at org.h2.engine.Database.startServer(Database.java:806)
at org.h2.engine.Database.open(Database.java:662)
at org.h2.engine.Database.openDatabase(Database.java:273)
at org.h2.engine.Database.(Database.java:267)
at org.h2.engine.Engine.openSession(Engine.java:64)
at org.h2.engine.Engine.openSession(Engine.java:176)
at org.h2.engine.Engine.createSessionAndValidate(Engine.java:154)
at org.h2.engine.Engine.createSession(Engine.java:137)
at org.h2.engine.Engine.createSession(Engine.java:27)
at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:349)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:115)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:99)
at org.h2.Driver.connect(Driver.java:69)
at org.jboss.jca.adapters.jdbc.local.LocalManagedConnectionFactory.createLocalManagedConnection(LocalManagedConnectionFactory.java:321)
… 57 more
Caused by: java.net.UnknownHostException: 44-206-124-178-static.mgts.by: 44-206-124-178-static.mgts.by: Name or service not known
at java.net.InetAddress.getLocalHost(InetAddress.java:1506)
at org.h2.util.NetUtils.getLocalAddress(NetUtils.java:271)
… 73 more
Caused by: java.net.UnknownHostException: 44-206-124-178-static.mgts.by: Name or service not known
at java.net.Inet4AddressImpl.lookupAllHostAddr(Native Method)
at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:929)
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1324)
at java.net.InetAddress.getLocalHost(InetAddress.java:1501)
… 74 more
15:49:37,514 FATAL [org.keycloak.services] (ServerService Thread Pool – 66) java.lang.RuntimeException: Failed to connect to database
