Hey,
I have question regarding the step-up authentication flow in the official documentation:
Server Administration Guide The attached picture [1] is described as:
If a client request a high authentication level, meaning Level of Authentication 2 (LoA 2), a user has to perform full 2-factor authentication: Username/Password + OTP. However, if a user already has a session in Keycloak, that was logged in with username and password (LoA 1), the user is only asked for the second authentication factor (OTP).
My issue with this explanation is the Cookie
auth step on the top, which is configured as Alternative
to Auth Flow
. Would that not invalidate the entire step-up mechanism? If you are authenticated you have a cookie, meaning the logic shown here is never evaluated past the very first login attempt, and no stepping up will ever happen as long as your cookie is valid, even if the client explicitly asks for LoA 2.
I would put Cookie
auth as Alternative
on the same level one step above Username Password Form
, because then it only serves as an alternative to password credentials, but does not influence the OTP sub-flow.
I am likely misunderstanding something, and would appreciate some help.
[1]
