we are trying to sync ldap users into our keycloak instance.
If set Userfederation -> LDAP -> ImportUseres Enabled
If we disable ImportUsers Login works.
We looked after the encoding and utf-8 is set in keycloak and in the postgres database korrektly.
When we try to sync the users, or try to login following Error occurs.
Error Message form the Logs:
Mär 05 13:55:57 sererv2 kc.sh[836]: 2025-03-05 13:55:57,675 INFO [org.keycloak.storage.ldap.LDAPStorageProviderFactory] (executor-thread-12541) Sync all users from LDAP to local store: realm: kommonitor, federation provider: ldap
Mär 05 13:55:58 sererv2 kc.sh[836]: 2025-03-05 13:55:58,903 WARN [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (executor-thread-12541) SQL Error: 0, SQLState: 22021
Mär 05 13:55:58 sererv2 kc.sh[836]: 2025-03-05 13:55:58,903 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (executor-thread-12541) ERROR: invalid byte sequence for encoding "UTF8": 0x00
Mär 05 13:55:58 sererv2 kc.sh[836]: Where: portal "C_44010" parameter $3
Thankyou in advance
